Prusa i3 Mk2 Nozzle Replacement
  1. Prusa i3 Mk2  Nozzle Replacement, Nozzle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement, Nozzle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement, Nozzle: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the 3D printer on using the power switch.
    • Move the head to the highest position on the Z axis. This provides working room to access the head.
    • Heat the nozzle up. This step depends on what type of filament is currently in the machine (e.g. 190 for PLA, 220 for ABS).
    • Remove filament from the 3D printer.
    • Clean off the old nozzle with tweezers.
  2. Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 1 X M3 Bolt holding on the fan shroud on the outlet of the fan.
    • Remove the fan shroud.
    • Remove the 2 X M3 Bolts holding on the blower fan.
    • Remove the fan and place it in a safe location.
    • The wires are still attached to the fan, be careful to not break the connectors.
  3. Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 X M3 Bolts from the Extruder Plate.
  4. Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M3 Bolts that are holding on the Extruder Cooling Fan.
    • Remove the Extruder Plate carefully, and avoid touching the hot metal print head.
    • Leave one bolt on the back of the fan so that the fan stays attached to the rest of the assembly.
  5. Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the nozzle is heated up before doing this step to prevent damage to the print head.
    • Use an adjustable crescent wrench and a 7mm wrench or socket to remove the old nozzle.
  6. Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Prusa i3 Mk2  Nozzle Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw in the new nozzle using a socket to get the threads started.
    • Use a crescent wrench and a 7mm wrench or socket to tighten a quarter turn past hand tight.
    • Do not over tighten. Damage to the nozzle or print head could occur.
    • Insert some new filament and push it through to test the connection.
To reassemble your device, follow these instructions in reverse order. Once reassembled, print a test print to ensure the replaced nozzle is not leaking.
Aubrey Woern
crwdns2935283:009/24/17crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team S5-G5, Galliah Fall 2017 crwdns2935289:0Michigan Tech, Team S5-G5, Galliah Fall 2017crwdne2935289:0
MTU-GALLIAH-F17S5G5
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 10,925
