Prusa i3 MK3 Y-Axis Bearings Replacement
  1. Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement, Y-Axis Bearings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the printer so that the screen is facing you.
    • Move the X-axis carriage to the highest Z-axis height for optimal accessibility.
    • Remove magnetic build plate.
  3. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the nine 2.5mm X 12mm flat-head countersink screws from the heat bead.
    • Lift and set the heat bed aside to access the heat bed mounting bracket.
  4. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the printer so that the screen is facing away from you.
    • Remove the two 2.5mm X 10mm socket head screws holding the Y-axis belt motor bracket.
    • During reassembly, these screws will be used to properly tension the Y-axis belt.
  5. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the side cutters to cut and remove the four zip ties that secure the Y-axis rods.
  6. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the heat bed mounting bracket assembly from the printer.
    • Remove the Y-axis rods from the heat bed mounting bracket assembly.
  7. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the heat bed mounting bracket assembly to access the bottom side.
    • Remove the Y-axis belt from the Y-axis belt grip.
    • Remove the heat bed mounting bracket assembly and set it aside to complete the next steps.
  8. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the heat bed mounting bracket so that you are looking at the top side.
    • Use the 5.5mm nut driver to remove the six 5.5mm u-bolt nuts.
    • Orient the heat bed mounting bracket so that you are looking at the bottom side.
    • Remove the three sets of U-bolts and Y-axis bearings.
  9. Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Prusa i3 MK3 Y-Axis Bearings Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, grease the Y-axis bearings with the PRUSA Lubricant Applicator.
    • When reinstalling the Y-axis bearings, the balls inside the bearings should form a diagonal "X", not a vertical "+".
To reassemble your device, follow these instructions in reverse order. Use Step 9 for reference.
Cade SmithMartin
crwdns2935283:001/23/24crwdne2935283:0
595 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G5
crwdns2942667:0crwdne2942667:0 193
