If you need to replace the filament sensor in your PRUSA i3 MK3, follow the steps in this guide. Ensure that you do not lose any of the parts or socket-head screws that are removed during replacement.
Orient the printer so that the screen is facing to the left.
Using the On/Off button, switch the printer into the Off position.
Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
Orient the printer so that the top of the extruder head can be accessed.
Remove the two 2.5mm X 10mm socket head screws. These screws secure the cover of the filament sensor.
Remove the filament sensor cover.
Orient the printer so that the screen is facing to the right.
Loosen the two 2.5mm X 40mm socket head screws while holding the extruder head firmly, keeping pressure on the opposite side.
Ensure the screws have cleared the embedded square nuts on the back side.
Remove the 3D-printed cover piece on top of the extruder access door. (Your printer might be missing this part.)
Orient the printer so that the screen is facing away from you.
Remove the 2.5mm X 30mm socket head screw located on the top left of the backside of the extruder head.
Rotate the printer so that the screen is facing to the left.
Remove the extruder access door from the extruder head.
Remove the 2.5mm X 10mm socket head screw located behind the extruder access door that was removed in Step 5.
Locate the filament sensor.
Hold the filament sensor in place while unplugging the wiring connection.
Remove the filament sensor.
To reassemble your device, follow these instructions in reverse order. During reassembly, ensure not to tighten the socket head screws too tight.
