crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Here's what we theoretically know about these pylons:
Uses Khaydarin crystals to channel energy
Takes 100 minerals and 30 seconds to warp in
Floats in the air and glows
Provides supplies for 8 units
Scientific analysis of our "prototype" specimen yields the following data:
2 unregulated USB ports capable of sourcing 2A total (or whatever max current it's supplied with)
The crystal can be activated to glow blue with a switch
Prototype: must be powered by a wired 5V 2.1A DC power supply
crwdns2935267:0crwdne2935267:0Manta Driver Kit - 112 Bit Driver Kit$69.95-
Luckily, we just got a shipment of high quality tools! And, they're so nice looking!
It's slightly unsettling that even the Protoss are using Phillips screws. It must be a universal standard.
The only thing worse than esoteric screw types? Low quality ones. These screws are made of soft metal and are easily stripped. This must be a side-effect of their warp-in technology.
Phew! It looks like the sensitive monitoring equipment survived the explosion. After we scrape up the charred remains of the interns, we shall proceed as planned.
And here we see the casualties of the warp-in technology:
Energy transfer conduits that are dangerously pinched
Low reliability conduit-to-socket connections
We finally get a glimpse of the Protoss' power channeling circuitry.
It is surprisingly sparse and low tech, consisting mostly of surface mount resistors and common electronic components...
We've been bamboozled by the Protoss! This isn't a real pylon; it's just a toy! A decoy!
Contact our field agents and fire them! Literally, with a Firebat executioner squad.
Speaking of being fired, someone’s going to have to take the fall for this. Wait right here! I’m going to go check on…something in the hanger bay…
crwdns2944067:06crwdne2944067:0
I thought that humans would get that long-awaited technology ... it seems that we will have to continue using crank motors ... This afternoon I may release zerg eggs on some of their planets :)
Ya’ll are nerds. Wonderful, wonderful nerds.
My life for Aiur!
On the main circuit where the DC socket is under the socket i fount no metal to solder for. They ‘ve actually solder the connector pins to plastic. Cheap work for 40Eur. You need to sratch the blue part to find some contact spot.
Fairly disappointed with this thing and the quality of the electronics but alas, it’s a toy made in china. Took me about 4 years to get around to it but I finally fixed the faulty power connector thanks to you guys. Thank you so much for this. I could not figure out where those clips were behind the larger sides.
