This guide will demonstrate how to remove and replace the front camera on the Protocol Vento drone.
Grasp the tail end of the drone where the lip of the battery protrudes.
Pull away from the drone to remove the battery.
To get into the drone, twelve total screws need to be removed:
Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
Two 4.5mm Phillips #000 screws at the front of the drone.
Flip the drone over and lift off the top plastic shell of the drone.
Remove the foam adhesive pad located on the Wi-Fi transmitter board.
Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
Lightly pull the ribbon cable away from the connector.
Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
Lift the camera holder and the camera up and away from the drone.
