Protocol TerraCopter EVO Drone Motor Replacement
  1. Protocol TerraCopter EVO Drone Motor Replacement, Drone Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orientate the drone to where the black side of the drone face upwards.
    • On the bottom side of the drone, remove the twenty-two 5mm Phillips #1 screws holding the black frame to the body.
    • There is one screw under the rear light. Pry the opaque cover to access the last screw.
  2. Protocol TerraCopter EVO Drone Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The plastic frames are subject to cracking.
    • Wires run through both frames.
    • Pry the white body away from the black frame.
  3. Protocol TerraCopter EVO Drone Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the motor from it's socket.
  4. Protocol TerraCopter EVO Drone Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol TerraCopter EVO Drone Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate these solder points of the leads on the motherboard.
    • From the front of the drone, the left motor has red and blue leads.
    • From the front of the drone, the right motor has white and black leads.
    • Remove the leads from their points on the motherboard with a soldering iron, respective to each motor.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
Derek Vande
crwdns2935283:010/03/19crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G22, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G22, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S1G22
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 269
