Protocol Slipstream WiFi Canopy Replacement
  1. Protocol Slipstream WiFi Canopy Replacement, Propeller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
  2. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the propeller off the device
    • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
    • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
  3. Protocol Slipstream WiFi Canopy Replacement, Propeller Guards: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 3 points where the propeller guard attaches to the device.
    • Place one finger on the body (black object) of the device and one finger under the propeller guard (silver object) and gently but firmly push the propeller guard up until it disconnects from the body at the 3 points circled in red.
    • There are two propeller guards on the device. One for each set of propellers. Each propeller guard has two locations that you have these 3 tabs to remove until you can replace it.
  4. Protocol Slipstream WiFi Canopy Replacement, Canopy: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Slipstream WiFi Canopy Replacement, Canopy: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5.5 mm Philips #00 screws that hold the lower canopy to the upper canopy.
    • Gently pull the lower canopy up and towards the back of the drone. The lower canopy will still be attached to the upper canopy by 3 wires. Just set the lower canopy aside and continue with the repair.
    • Be very careful when pulling the lower canopy apart from the upper canopy. There are 3 wires that will still be attached between the lower and upper canopies.
  5. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.5 mm Philips #00 screws that hold the motor cover onto the upper canopy.
    • Gently pull up on the motor cover until it disconnects from the upper canopy.
    • Repeat this step for the other 3 motor covers.
  6. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the motor and pull the motor out of the upper canopy slot.
    • Be careful pulling the motor out of the slot in the upper canopy. The motor will still be attached to the main computer by 2 wires.
    • Repeat this step for the other three propeller motors.
  7. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.0 mm Philips #00 screws that hold the computer to the upper canopy.
  8. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat side of the spudger to gently pry the computer from the upper canopy.
    • Be very gentle prying on the computer. If you pry too hard, the computer may get damaged or break.
    • Separate the upper canopy from the rest of the parts.
  9. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5.5 mm Phillips #00 screws that holds the battery tray to the lower canopy.
    • Once the four 5.5 mm Philips #00 screws are removed, gently pull on the battery tray to separate it from the lower canopy.
  10. Protocol Slipstream WiFi Canopy Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to gently pry around the outside edge of the camera to remove the camera from its mounting hole.
    • Be careful when removing the camera from its mounting hole as there is a small ribbon wire that connects it to the computer.
    • Remove the camera and computer assembly from the lower canopy.
John Burkee
crwdns2935283:009/17/19crwdne2935283:0
445 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S13-G5, Lamothe Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S13-G5, Lamothe Fall 2019crwdne2935289:0
ERAU-LAMOTHE-F19S13G5
crwdns2942667:0crwdne2942667:0 248
