This guide will walk you through how to safely and effectively remove the battery from your drone. This is a relatively simple process that does not require any tools or prerequisite steps. This guide is not required to charge your drone battery, but may be useful if the battery becomes defective.
Locate the door to the battery compartment on the underside of the drone.
Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
First pull out the wires located to the side of the battery.
Carefully remove the battery from the battery compartment
Disconnect the two ends of the wires by lightly pulling them apart.
Please were can buy the battery
odoffin Kehinde - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
