Protocol Galileo Pinion Gear Replacement
  1. Protocol Galileo Pinion Gear Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Pinion Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Pinion Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Pinion Gear Replacement, Propeller: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement, Propeller: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Pinion Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Pinion Gear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Protocol Galileo Pinion Gear Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Pinion Gear Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off propeller.
  9. Protocol Galileo Pinion Gear Replacement, Top Shell: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement, Top Shell: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement, Top Shell: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Pinion Gear Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Pinion Gear Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Pinion Gear Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Pinion Gear Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Pinion Gear Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Pinion Gear Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Pinion Gear Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Pinion Gear Replacement, Pinion Gear: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Pinion Gear Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Pinion Gear Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pinion gear off of the motor assembly.
Thomas Ramey
crwdns2935283:002/03/17crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 2-3, Rose Winter 2017 crwdns2935289:0UW Tacoma, Team 2-3, Rose Winter 2017crwdne2935289:0
UWT-ROSE-W17S2G3
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 401
