ProtoCentre 999 Extruder fan Replacement
    • We want to check the fan is running or not.
    • If you place your hand near your fan, you can understand the fan is running or not.
    • In some case , the fan speed may get reduced. In this case also we want to put new fan. Else the may effect the working of the nozzle.For checking this, GO TO PREPARE
    • PREHEAT the machine
    • After getting preheated, place your hand near fan, if the fan is pulling out less hot air, you has to change the fan.
    • Remove the fan from the nozzle block with the help of allen key.
    • Remove the back cover of the machine.
    • In the 12V supply PCB there will be a connection for extruder fan, remove it. And take the fan out.
    • Change the fan with new fan.
    • Reconnect the fan connection in the 12V supply PCB.
    • Connect the fan in the nozzle block with the help of allen key.
    • After connecting the fan back, check the fan speed with the help of your hand placing near the fan.
abhishek j
crwdns2935283:006/27/17crwdne2935283:0
1,193 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 121
