After rough flights the stabilizer beam may end up getting damaged. Without a working stabilizer beam, the gyro-copter will not fly as it should. The best way to fix this is by replacing the stabilizer beam completely.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
Remove the two 6.0 mm Phillips #00 screws from the rotors.
Pull the rotors away from the mounting brackets.
Remove the two 5mm PHillips #00 screws screws
Using the tweezers twist the rotor attachment bracket apart.
Pull up on the stabilizer assembly to remove it completely from the drive shaft.
Where can I get these stabilizers
