Propel Gyro-X Drive Gears Replacement
    1. Propel Gyro-X Drive Gears Replacement, Top Propellor Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Stabilizing links are easy to break. Be gentle when prying them off.
      • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
    2. Propel Gyro-X Drive Gears Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Gyro-X Drive Gears Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 6.0 mm Phillips #00 screws from the rotors.
    3. Propel Gyro-X Drive Gears Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Gyro-X Drive Gears Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the rotors away from the mounting brackets.
    1. Propel Gyro-X Drive Gears Replacement, Bottom Propellor Blades: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 5.0 mm Phillips #00 screws from the rotors.
      • The blades will fall off when the screws have been removed.
    1. Propel Gyro-X Drive Gears Replacement, Outer Shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the nubs on either side of the helicopter.
    2. Propel Gyro-X Drive Gears Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the body shell off of the nubs on both sides.
    3. Propel Gyro-X Drive Gears Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Gyro-X Drive Gears Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the front of the nose back towards the tail of the helicopter.
      • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
    1. Propel Gyro-X Drive Gears Replacement, Drive Gears: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
    2. Propel Gyro-X Drive Gears Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 mm Phillips #00 screw from the tail.
    3. Propel Gyro-X Drive Gears Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Propel Gyro-X Drive Gears Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Propel Gyro-X Drive Gears Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingers to free the motor casing from the body, by bending the plastic body casing outwards at each of the four nubs.
      • Pull the motor casing upwards from the body.
      • The drive gear will slide out when you lift the motor casing.
Jack Jenner
crwdns2935283:004/08/15crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-2, Forte Spring 2015 crwdns2935289:0Cal Poly, Team 17-2, Forte Spring 2015crwdne2935289:0
CPSU-FORTE-S15S17G2
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 3,721
