Propel Graviton Rotor Assembly Replacement
  1. Propel Graviton Rotor Assembly Replacement, Rotor Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Graviton Rotor Assembly Replacement, Rotor Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  2. Propel Graviton Rotor Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4mm screw that holds the propeller to the axle using a Phillips #00 screwdriver.
    • When re-assembling your drone, be careful not to over tighten the screws. The drone body is made of soft plastic, doing so may strip the screws' housing and prevent them from holding.
    • Remove the propeller by pulling it upwards away from the assembly.
  3. Propel Graviton Rotor Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Graviton Rotor Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 6mm screws holding the propeller guard with a Phillips #00 screwdriver
    • The drone motor may be magnetized, making it difficult to remove or install the screws. Using the tweezers to grip them is recommended.
  4. Propel Graviton Rotor Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your finger, gently push on the top of the propeller axle and remove out of the bottom of its housing.
    • Ensure the axle is cleared of debris.
  5. Propel Graviton Rotor Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Graviton Rotor Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wheel bearing from the axle using your fingers.
    • Remove the wheel bearing from the axle housing with a pair of tweezers.
    • Ensure the axle housing is clear of debris.
  6. Propel Graviton Rotor Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6mm screws with a Phillips #00 screwdriver.
    • Some of the screws may not completely remove from the black housing. A slight tap may jar them loose, but this is not necessary.
  7. Propel Graviton Rotor Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Propel Graviton Rotor Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the top and bottom drone housing apart with a spudger to reveal the motor.
    • Ensure the housing is cleared of debris.
    • Replace the motor (if it is necessary).
Kyle Mott
crwdns2935283:008/25/20crwdne2935283:0
215 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G5, Cromer Twal Fall 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G5, Cromer Twal Fall 2020crwdne2935289:0
ERAU-CROMER TWAL-F20S3G5
I have a PROPEL GRAVITON drone and have not had it out in awhile. I got it out tonight and noticed a wire coming from the back of the camera, but I don't see where it is supposed to be attaches on the other end. None of the pics I see of this drone show this wire, though I wonder if it may be an antenna wire or something. Do you have any ideas?
Bobbi P - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 680
