crwdns2959928:0crwdne2959928:0 ↓Handheld devices such as this tablet are very commonly dropped. Even dropping your device small heights can result in shattering or breaking the screen. This guide demonstrates how to remove other components inside the device to access the screen for removal and replacement.
Spudger4.9
Place the tablet face-up on a flat table
Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
Remove all of the yellow tape that is on the device with the spudger.
Use the flat end of the spudger to gently pry the battery from the back of the screen.
Use a spudger to lift all the ribbon cable clamps
Detach all three ribbon cables from the clamps
Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
crwdns2935267:0crwdne2935267:0Heavy-Duty Spudger$4.99
Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
Remove the orange tab from the back of the screen as shown in the picture
Use the flat end of the metal spudger to unclip and remove the screen from the casing.
