ProntoTec Axius Motherboard Replacement
  1. ProntoTec Axius Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
  2. ProntoTec Axius Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove only the yellow tape that touches the motherboard
    • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
  5. ProntoTec Axius Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
    • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
  6. ProntoTec Axius Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    • Use pliers to pull the wire from the board
  7. ProntoTec Axius Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
  8. ProntoTec Axius Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
    • Gently pull and remove the ribbon cables from the motherboard
  9. ProntoTec Axius Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProntoTec Axius Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
Estelle Hatem
crwdns2935283:010/20/16crwdne2935283:0
156 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-3, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 301
