ProntoTec Axius Battery Replacement
  1. ProntoTec Axius Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger remove all the tapes that touches the battery.
    • Be careful not to cute any wires that are under the tapes
  5. ProntoTec Axius Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
    • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
  6. ProntoTec Axius Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
  7. ProntoTec Axius Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProntoTec Axius Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
Antonio Irons
crwdns2935283:010/20/16crwdne2935283:0
441 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-3, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G3
crwdns2942667:0crwdne2942667:0 530
