crwdns2959928:0crwdne2959928:0 ↓If your ProScan's audio is not working, use this guide to replace the speakers. This guide will require soldering.
Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
Use the blue plastic opening tool to pry open the tablet.
Pull back the protective tape from the two wires that connect the speakers to the motherboard.
Use the soldering tool to remove speaker wires from motherboard.
If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
