ProScan PLT7223G Screen Replacement
  1. ProScan PLT7223G Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 4 mm screws from the motherboard.
  4. ProScan PLT7223G Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
    • Pull back the black tape with the spudger until it can be lifted up with your fingers.
    • Use your fingers to grab and lift the remainder of the black tape from device panel.
  5. ProScan PLT7223G Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
  6. ProScan PLT7223G Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool underneath the silver base of the internal device element.
    • Use the opening tool to pry the element out of the case that holds the screen.
    • You will need to release a number of clips in order to remove the screen.
    • Be careful not to damage the motherboard or battery as you go.
Nathaniel Girard
crwdns2935283:001/12/16crwdne2935283:0
290 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-4, Rowley Winter 2016 crwdns2935289:0Eastern Washington University, Team 1-4, Rowley Winter 2016crwdne2935289:0
EWU-ROWLEY-W16S1G4
crwdns2942667:0crwdne2942667:0 1,911
