ProScan PLT7223G Screen Replacement
    1. ProScan PLT7223G Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
    2. ProScan PLT7223G Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
    3. ProScan PLT7223G Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove three 4 mm screws from the motherboard.
    4. ProScan PLT7223G Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
      • Pull back the black tape with the spudger until it can be lifted up with your fingers.
      • Use your fingers to grab and lift the remainder of the black tape from device panel.
    5. ProScan PLT7223G Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
    6. ProScan PLT7223G Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert an opening tool underneath the silver base of the internal device element.
      • Use the opening tool to pry the element out of the case that holds the screen.
      • You will need to release a number of clips in order to remove the screen.
      • Be careful not to damage the motherboard or battery as you go.
Nathaniel Girard
crwdns2935283:001/12/16crwdne2935283:0
290 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-4, Rowley Winter 2016 crwdns2935289:0Eastern Washington University, Team 1-4, Rowley Winter 2016crwdne2935289:0
EWU-ROWLEY-W16S1G4
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 2,249
