ProScan PLT7223G Motherboard Replacement
crwdns2942287:0crwdne2942287:0If your device isn't working and other troubleshooting methods have failed, or a component of the motherboard has failed, use this guide to replace the motherboard and make your device functional again.
crwdns2944105:0crwdne2944105:0
Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
Use the blue opening tool to pry the tablet open.
Remove all yellow tape from the motherboard.
With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
Lift all three ZIF connectors to disconnect the ribbon wire.
Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
