If your device will not turn on at all, use this guide to replace your dead or dying battery and make your device functional again.
Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
Use the blue plastic opening tool to pry open the tablet.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
Use a spudger to remove the black tape from the battery.
Using the flat end of a spudger, carefully separate the battery from the base of the device.
what is the number of the replacement battery??
How will I know if my proscan tablet battery is no good once I remove it
