ProScan PLT7050 Motherboard Replacement
  1. ProScan PLT7050 Motherboard Replacement, Open Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProScan PLT7050 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProScan PLT7050 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ProScan PLT7050 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ProScan PLT7050 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ProScan PLT7050 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
Valerie Landguth
crwdns2935283:001/19/17crwdne2935283:0
320 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-4, Mathisen Winter 2017 crwdns2935289:0Eastern Washington University, Team 1-4, Mathisen Winter 2017crwdne2935289:0
EWU-MATHISEN-W17S1G4
crwdns2942667:0crwdne2942667:0 424
