Princess Compact Blender Rubber Gasket Replacement
  1. Princess Compact Blender Rubber Gasket Replacement, Rubber Gasket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the glass container of the motor
    • The motor is the bottom part of the blender
    • If your blender has recently been used, you may want to clean it before taking it apart
  2. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the base from the glass container. The right direction is indicated by the red arrow.
    • The base is the part whereon the blades are attached
  3. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift metal blades with the metal hood out of the base
    • Watch out for sharp blades or wear gloves
    • Large rubber ring may fall out of the base, this is no problem, just put it back in place
  4. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the cutting blades in one hand and the black, plastic connector part in the other
    • This is where you could use the gloves
    • Unscrew the latter together with the screw-nut from the axis by twisting
    • If necessary, apply a little force to slightly pull it out
    • To unscrew, you have to twist right. The “righty tighty, lefty loosy-principle” does not apply here
  5. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide off the hood and lower, small metal protective ring from the axis and don’t lose the rubber ring!
  6. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the broken ring off the axis
    • Replace the broken ring for a new one
  7. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the remaining parts back on the axis in the following order:
    • Metal hood
    • Small metal protective ring
    • Black plastic connector
    • Screw back the screw-nut on the thread with the pliers to fasten the assembly
    • Put the blade-assembly back in the base
  8. Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Princess Compact Blender Rubber Gasket Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the base back onto the glass container
    • Put the glass container on the stand (bottom part of the blender, containing the motor)
    • Start making your smoothie!
marieke.vandijk
crwdns2935283:003/08/17crwdne2935283:0
Delft University of Technology, Team S1-G20, Flipsen Spring 2017 crwdns2935289:0Delft University of Technology, Team S1-G20, Flipsen Spring 2017crwdne2935289:0
TUD-FLIPSEN-S17S1G20
crwdns2942667:0crwdne2942667:0 3,366
