By wear and tear the rubber ring underneath the blades of the blender may rip, making the blender inoperable. With the help of this repair guide you will be able to replace the ring, reassemble the blender and start making your smoothie again!
Lift the glass container of the motor
The motor is the bottom part of the blender
Unscrew the base from the glass container. The right direction is indicated by the red arrow.
Lift metal blades with the metal hood out of the base
Take the cutting blades in one hand and the black, plastic connector part in the other
Unscrew the latter together with the screw-nut from the axis by twisting
If necessary, apply a little force to slightly pull it out
Gently slide off the hood and lower, small metal protective ring from the axis and don’t lose the rubber ring!
Slide the broken ring off the axis
Replace the broken ring for a new one
Slide the remaining parts back on the axis in the following order:
Metal hood
Small metal protective ring
Black plastic connector
Screw back the screw-nut on the thread with the pliers to fasten the assembly
Put the blade-assembly back in the base
Twist the base back onto the glass container
Put the glass container on the stand (bottom part of the blender, containing the motor)
Start making your smoothie!
