These instructions explain how to take apart the popcorn popper. This could be useful if it is not working properly or if the stirrer is jammed. The only tool needed is a #2 Phillips screwdriver. All the screws except the four large screws attaching the base to the heating plate are identical. Be careful with exposed wires and do not plug in the popper without the wires connected properly.
Detach the cover/serving bowl from the popper.
Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
Removing the bottom cover exposes the internals of the popper. The base holds together the centrally mounted motor and the wires for the power cord and heating element.
Remove the two black wire twist caps, and unwind the different wires.
Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
Remove the two 14 mm Phillips #2 screws from the motor.
Remove the motor from the popper.
Remove the four 50 mm screws attaching the base to the heating pan.
Remove the base from the rest of the device.
This is the nonstick heating pan with the stirrer still attached.
The center stirring arm knob can be removed by hand (twisting to the left).
The scalloped stirring arm can be directly lifted out from the center mount.
Remove two Phillips screws to detach the thermostat.
