crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
If it is still attached, disconnect the black hose from the recovery tank.
Unclasp and release the two black latches on either side of the carpet extractor.
Use a Phillips #2 screwdriver to remove the two 1/2" screws and washers securing the vacuum motor retainer.
Remove the vacuum motor cover, retainer, and gasket as one piece.
Gently pull the vacuum motor up and out of the extractor housing and lay it on its side.
Use a Phillips #2 Screwdriver to remove the 3/8" terminal screw securing the motor's three ground wires.
Use a pair of wire cutters or scissors to cut and remove the zip tie secured around the black, yellow, and green motor wires.
Disconnect the two black motor wires from the switch mounted inside the carpet extractor housing.
crwdns2935229:05crwdne2935229:0
