Remove the head pillow by simply peeling it back . Its only attached with Velcro.
Next unzip the very top zipper.
Unzip Both left and right zippers . These zippers are found in between the shoulder airbag and back cushion.
Unzip seat zipper. this can be found next to the hip airbag on the right side .
Last thing in order to completely remove the back pad is to unplug the backrest heater cable. This can be found on the lower right hand side on the back side of the back pad.
Now unzip the silk. Zipper is usually tucked at the bottom near the seat area
On the back side of the chair there is a plastic cover. Remove the 2 phillips head bolts.
You will need to follow the heating element wire to the back side of the mechanism .
Wires are bundled in the marked area . Please cut all zip ties nessecary to access these wires.
remove nut using a wrench . There should also be a small washer but they usually get stuck inside , they should fall out during the next step.
Next this bolt will need to be tapped out . you can either LIGHTLY tap it with a wrench from the threaded end ( see last step) or you can use vice grips .
To reassemble your device, follow these instructions in reverse order. Be sure you are putting your zip ties in reasonable places , you don't need to use as many as the factory has used . Just be smart about the placement making sure wires are not in pinch point areas .
Hi Nick is there any way I can contact you to ask about a part that im looking for for a massage chair im trying to repair? its an easy fix but i cannot for the life of me find the product or what its called - if possible please contact me a_hammond@outlook.com it would be much appreciated
