crwdns2956850:0crwdne2956850:0 crwdns2956756:0crwdnd2956756:0crwdne2956756:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
crwdns2959928:0crwdne2959928:0 ↓The engine block is removed from the bottom of the vehicle.
Place the vehicle on a car lift. We will need to raise and lower the vehicle several times.
Disconnect the cooling hoses and let as much fluid as possible drain out.
Place a collection pan under the transmission.
Remove the filler plug.
Loosen the transmission drain plug.
Allow the oil to drain.
Air filter housing outlet duct
Exhaust muffler
Torque strut
Gearbox breather hose
Clutch line
Move the wiring harness and ground wire located in the rear right wheel well.
Unscrew the following items
Disconnect the following cables
Remove the following screws
Fuel vapor absorber
Fuel supply line
Remove the 2 diagonal screws from the rear axle crossmember.
Position the rear crossmember removal and installation tool in place of these two screws.
Slowly loosen the two nuts on the threaded rods of the removal and installation tool to slowly lower the rear axle crossmember.
Use the necessary items and tools to support the engine block.
Release the lower transmission and engine mounts.
Slowly raise the vehicle to lower the engine block.
Remove the transmission and engine silent blocks.
Position the engine support tools in place of the silent blocks.
Raise the vehicle.
Remove the support from under the engine block.
Perform the necessary operations
Disconnect the following hoses
Unplug the following connectors
Alternator wire harnesses
Starter wire harnesses
Loosen the following screws
Lift the vehicle
Remove the engine block
Give the engine block a hug and perform absolutely every operation that can be done, even preventative maintenance, while it is easy to work on the engine block.
