PowerShot G7 X Mark II LCD Screen Replacement
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is detached and can now be replaced.
crwdns2935229:05crwdne2935229:0
Brandon
crwdns2935283:002/15/17crwdne2935283:0
644 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-3, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 12-3, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S12G3
crwdns2947412:05crwdne2947412:0
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - crwdns2934203:0crwdne2934203:0
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - crwdns2934203:0crwdne2934203:0
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - crwdns2934203:0crwdne2934203:0
on ebay or amazon. you can order it
nicole -
crwdns2936753:030crwdne2936753:0 168
crwdns2942667:0crwdne2942667:0 9,743
