This guide will show how to replace the LCD screen on the camera. This replacement is useful if the LCD screen has been cracked or has stopped working.
Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
Use a spudger tool to release the ribbon cable from the ZIF connector.
Gently pry off the screen until the double-sided tape behind the back panel gives in.
The screen is detached and can now be replaced.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
on ebay or amazon. you can order it
nicole - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
