PowerLead Puto PLD003 Lens Replacement
  1. PowerLead Puto PLD003 Lens Replacement, Side Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerLead Puto PLD003 Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure to the back panel (away from the camera) to remove.
  8. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cable should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the lens easier
  10. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 4 mm Phillips #1 screws holding onto the lens casing
    • There are also two 4 mm Phillips #1 screws on the other side holding onto the lens casing, remove them as well.
  11. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull forward on the lens casing to remove it. The cord connecting the light to the motherboard should still be attached.
  12. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 4 mm Phillips #1 screws holding the plastic lens holder.
  13. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic lens holder.
  14. PowerLead Puto PLD003 Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the lens out of the plastic casing from the back.
Justin Tew
crwdns2935283:003/31/16crwdne2935283:0
767 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Giguere Spring 2016 crwdns2935289:0Eastern Washington University, Team 1-2, Giguere Spring 2016crwdne2935289:0
EWU-GIGUERE-S16S1G2
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 262
