Use this guide to replace/remove the joysticks of a Power A Spectra Infinity Enhanced Xbox controller.
The joysticks may need to be replaced if they’re worn down, sticky, cracking, or causing unintentional user input. Please ensure the controller is not plugged in before taking it apart.
Flip the controller so the back is facing up.
Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
Unlock the trigger locks before removing the backplate.
Use your fingers and carefully remove the backplate.
Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
Use your hand to separate the motherboard from the face plate.
Take the motherboard and place it with the joysticks facing upward.
Use your hand to carefully remove the joysticks from the motherboard.
