Power rack&pinion steering Replacement
  1. Power rack&pinion steering Replacement, Power rack&pinion steering: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Power rack&pinion steering Replacement, Power rack&pinion steering: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Power rack&pinion steering Replacement, Power rack&pinion steering: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From inside the vehicle on drivers side use a 11mm socket to remove the three nuts that secure the boot to the firewall
    • Using a 10mm sockstRemove the two pinch bolts form the shaft and remove shaft & boot
    • raise and support the front of the vehicle
    • place the jack stands in the reinforced area just behind the engine cradle
    • Use a 19mm socket remove both front tires
    • remove the cotter pin and castle nuts from tie rod ends
    • remove tie rod ends from steering knuckle
    • remove the two Nuts and Bolts that secured flex pipe to the y pipe
    • From inside the engine compartment remove the three nuts that secure the strut to the strut Tower on both sides
    • place a floor jack with a short piece of 2 by 6 under the transmission pan
    • Raise Jack until it just starts to lift the transmission
    • loosen the two front bolts of the subframe but do not remove
    • remove the two Bolts from the rear of the subframe
    • Slowly lower jack in till you have about 4 inches of clearance
    • Remove the two nuts that secure the steering rack to the subframe
    • Lift the steering rack up until the bolts clear rotate rack to gain access to the hose fittings and remove
    • Slide rack to the left and remove thru drivers side wheel well
    • Transfer any parts needed from old rack to the new rack
    • Install in reverse order
Brian Robinson
crwdns2935283:003/10/16crwdne2935283:0
128 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 1,469
