Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Lay the computer on its side, ensuring that where the side access panel was is facing up.
Unlock the top chassis by moving the two green locking latches upward and outward.
Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
Remove the screw at the back of the computer holding the I/O card in place.
Remove the two screws inside the computer securing the I/O card to the metal chassis.
Gently lift up the I/O card to remove it from the computer.
Remove the piece of black plastic holding the battery in place.
Remove the battery.
