Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Lay the computer on its side, ensuring that where the side access panel was is facing up.
Unlock the top chassis by moving the two green locking latches upward and outward.
Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
Gently pry up the four tabs on the top side of the speaker bezel.
Swing the speaker bezel open.
Release the eight tabs on the bottom side of the speaker bezel and remove the bezel from the computer.
