Power Macintosh G3 (Minitower) Hard Drive Assembly Replacement
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Unscrew the two Phillips screws holding the hard drive in place.
    • The hard drive and its carrier should come off together.
    • Unplug the IDE and Molex cables from the hard drive.
    • Be sure to be careful when removing the IDE cable so as to not damage the pins on the hard drive. (Instead of yanking it, pry it off from side to side.)
LeoI07
crwdns2935283:006/10/21crwdne2935283:0
1,573 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2942667:0crwdne2942667:0 564
