Power Macintosh G3 (Minitower) Floppy Drive Assembly Replacement
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Gently pry up the tab on the left side of the floppy drive bezel.
    • Swing the bezel open.
    • Remove the bezel from the right edge of the floppy drive.
    • Using a Phillips screwdriver, remove the two floppy drive shield screws.
    • Remove the floppy drive shield.
    • Disconnect the floppy drive cable from the back of the floppy drive.
    • Slide the floppy drive carrier and drive out of the front of the computer.
    • Replacement Note: When inserting the drive into the computer, make sure the drive carrier aligns with the carrier guides. The carrier should slide between five metal tabs below and two metal tabs above the left and right edges of the carrier.
LeoI07
crwdns2935283:006/10/21crwdne2935283:0
1,573 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 90
