crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace/upgrade the RAM in your Power Mac G5.
Remove all the cables, including the power cables before opening the unit.
Lift the tab to unlock the side panel.
Remove the air deflector (the clear plastic cover) by pulling on the handle.
Locate the front fan assembly.
Pull the fan assembly out; it should slide out easily.
Locate the RAM on the Power Mac G5.
Use your thumbs to push the RAM ejector pins to the sides.
Remove the RAM module from the DIMM slot.
crwdns2935229:061crwdne2935229:0
Major thing to note, you must install RAM in pairs. You can't just install one card on the top and not one on the bottom. Pairs start from the center and move outwards.
Red Rabbit 90 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
