Learn how to replace the PRAM battery in your Power Mac G5. The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Remove all the cables, including the power cables before opening the unit.
Lift the tab to unlock the side panel.
Remove the air deflector (the clear plastic cover) by pulling on the handle.
Locate the battery inside the desktop.
Remove the battery by lifting the battery from the battery terminal.
The area should look like this after the battery is removed.
crwdns2935229:035crwdne2935229:0
crwdns2944067:07crwdne2944067:0
plz advise the type of battery, thx !
Thank you, very very instructive - but why on Earth
does Apple not mark the battry holder on this model
with + and - ? ? Now, thanks to your close-up photo
I found out which way to turn the battery. (I hope)
Best regards
Torben, Denmark
Agreed - slot should be marked with + and – . . .
Thanks for the clear and sharp photos d;-)
This is not valid for the late 2005 model of G5…Model 11,2.
It uses a coin shaped Panasonic Lithium battery. I just ordered one from OWC.
($.88)
Grazie, molto utile! Alberto da Venezia
Nice guide. I wish they indicated which direction the battery goes on on the board itself.
Take a picture of the Battery position in the computer before you take it out (for us people with not-so-good memory).
