Use this guide to replace the CD-ROM drive in your Power Mac G5.
Remove all the cables, including the power cables before opening the unit.
Lift the tab to unlock the side panel.
Remove the air deflector (the clear plastic cover) by pulling on the handle.
Locate the CD-ROM Drive on the top left corner of desktop.
Detach the first cable from the CD-ROM drive.
Detach the second cable from the CD-ROM drive.
After the CD-ROM drive is removed, the area should look like this.
crwdns2935229:044crwdne2935229:0
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
