Power Mac G4 M5183 Logic Board Replacement
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - crwdns2934203:0crwdne2934203:0
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement, Logic Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Power Mac G4 M5183 Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
crwdns2935229:015crwdne2935229:0
Justin Petrilli
crwdns2935283:001/21/10crwdne2935283:0
3.114 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 13-24, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-24, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G24
crwdns2935297:025crwdne2935297:0
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - crwdns2934203:0crwdne2934203:0
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 18,415
