Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement
  1. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement, Primer Bulb, Fuel Lines, Filters: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement, Primer Bulb, Fuel Lines, Filters: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement, Primer Bulb, Fuel Lines, Filters: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three T25 screws on the top cover.
    • Remove the top cover and set aside.
  2. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the top cover off, disconnect the spark plug.
  3. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four T25 screws securing the starter assembly to the (side) of the chainsaw.
    • Remove the starter assembly and set aside.
  4. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the air filter cover and set aside.
    • Remove the air filter from the housing and set aside.
  5. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the single T25 screw securing the air filter housing to the carburetor.
    • Remove the two 5/16"nuts securing the air filter housing to the carburetor.
  6. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or flat head screwdriver to disconnect the kill switch wire.
  7. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air filter housing from the carburetor.
    • Let the air filter housing rest on the side of the chainsaw.
  8. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flat head screw driver or opening tool to disconnect the (primer-side) fuel line from the carburetor.
  9. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the choke lever from the carburetor and set aside.
  10. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull and hold the throttle trigger to expose the throttle linkage attachment point (on the trigger).
    • Disconnect the linkage from the throttle trigger.
    • Disconnect and remove the throttle linkage from the carburetor.
    • Set the throttle linkage aside.
  11. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the carburetor assembly off the mounting bolts and away from the engine.
    • The fuel return line may still be attached to the carburetor. In my case the fuel line was disintegrated. If it is still attached remove with a flat head screw driver or spudger.
  12. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a flat head screwdriver or spudger to press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing).
    • Pull the damaged primer bulb out of the engine housing.
    • Use long needle nosed pliers to disconnect the two fuel lines from the primer bulb.
  13. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the primer suction line was damaged, slide the carburetor back onto the mounting bolts.
    • Attach one end of the new fuel line to the incoming fuel port on the carburetor.
    • Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line.
    • Mark desired length and cut to size.
    • If the old primer suction line was intact, you can measure and cut a new piece of fuel line to the same length and attach it to the intake port on the primer bulb and intake port on the carburetor.
  14. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the cut end of the primer fuel line to the intake port of the primer bulb (shorter nipple).
    • Slide the carburetor back off of the mounting bolts.
    • Cut and remove the remaining old fuel lines by pulling them through the housing.
  15. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the gas cap.
    • Pull out and remove old fuel lines and fuel filter.
  16. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is an example of how the fuel lines will attach to the carburetor and primer bulb.
    I want to see how the fuel filter fits inside the fuel tank. I can’t keep it from leaking around the tubing.
    Larry Mayer - crwdns2934203:0crwdne2934203:0
  17. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push a piece of scrap wire through the larger hole (fuel filter line).
    • Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank.
  18. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut a piece of the thicker diameter fuel line at a sharp angle.
    • Pierce the wire through the fuel line and twist the wire with pliers.
  19. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the fuel line through the gas tank while pulling the wire.
    • Use pliers to continue to pull the fuel line through the housing.
  20. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the wire through the small hole (fuel return).
    • Attach the wire to the cut end of the thinner diameter fuel line as in the previous step.
    • Feed the fuel line through the gas tank while pulling the wire as in the previous step.
    • Pull both fuel lines up through the housing.
  21. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using 2-cycle oil as lubricant on the fuel lines will make it easier to pull them through the housing.
  22. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut both of the fuel lines flush (removing the angle that was previously cut).
  23. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor.
    • Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple).
    • Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank.
    What’s the name of that small black tap look piece?
    Jessica Rios - crwdns2934203:0crwdne2934203:0
  24. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the primer bulb back into the housing.
    • Cut the smaller diameter fuel line (fuel return line) and push it into the gas tank.
    • The fuel return line should be at the bottom of the tank.
  25. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the fuel filter line and attach the new fuel filter.
    • Push the fuel filter line into the gas tank.
    • The fuel filter should rest at the bottom of the gas tank.
  26. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the throttle linkage to the carburetor linkage.
    • Pull and hold the throttle trigger to expose the attachment point for the trigger-portion of the throttle linkage.
    • Connect the throttle linkage to the throttle trigger.
  27. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the choke lever.
    • Slide the air filter housing back onto the carburetor mounting bolts.
    • Secure the air filter housing with the two 5/16" nuts.
    • Secure air filter housing with one T25 screw.
  28. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install the new air filter onto the air filter housing.
    • Install the air filter cover.
    • Connect the kills switch wire.
  29. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the starter assembly onto the engine.
    • Secure the starter assembly with four T25 screws.
    • Pull the starter rope slowly until the flywheel engages the starter assembly.
  30. Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Poulan P3314 Primer Bulb, Fuel Line, and Filters Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reconnect the spark plug.
    • Install the top cover and secure with three T25 screws.
    Terrific guidlines! I wasn't able to complete the work in 45 minutes - primarily because pulling the fuel lines through was a difficult task - but your detailed steps helped me make sense of the project. Thanks! - David Garrison
    David Garrison - crwdns2934203:0crwdne2934203:0
crwdns2935229:038crwdne2935229:0
Chad Monteleone
crwdns2935283:009/18/17crwdne2935283:0
1,148 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team S4-G44, Prince Fall 2017 crwdns2935289:0Pasco Hernando, Team S4-G44, Prince Fall 2017crwdne2935289:0
PHSC-PRINCE-F17S4G44
crwdns2944067:020crwdne2944067:0
Any idea where I downloaded shop manuals for small engin repairs looking for stihl 039 manual
Daniel - crwdns2934203:0crwdne2934203:0
Yes I would try manuals.lib at the Google play store.
Randy Clawson -
Excellent instructions
Thank You
Ron Bishop - crwdns2934203:0crwdne2934203:0
How do you choose the best choose the best product among the ones listed here? <a href="https://onlychainsaw.com/best-scroll-saw... ">https://onlychainsaw.com/best-scroll-saw... </a>
ross jonnes - crwdns2934203:0crwdne2934203:0
Excellent job in describing the process! Thanks!!
Antonio Gutierrez - crwdns2934203:0crwdne2934203:0
Hello, I noticed you might have gotten your fuel lines mixed up. Im not sure if it would make any difference in the operation of the chainsaw.
But during the disassembly stage, you have the thick fuel return line going from the purge bulb outlet port to the big hole towards the front of the fuel tank. Yet during the reassembly stage, you used this same hole for your fuel supply line instead.
The correct routing of the fuel lines is actually the way it was before you disassembled it.
Basically:
1: Thin line from right carburetor nipple gets routed through the small hole towards the rear of the fuel tank and is hooked up to the fuel filter inside.
2: Thick line goes from left carburetor nipple to the short nipple on the purge bulb.
3: And finally, another thick line goes from the long nipple of the purge bulb to the big hole towards the front of the fuel tank.
ajisup - crwdns2934203:0crwdne2934203:0
Hey Chad, thanks a bunch for a an excellent set of instructions. You saved me a lot of time and money!
Judas - crwdns2934203:0crwdne2934203:0
Great information here, I’ll use it to do the same job on my McCulloch 2214AV, it is almost identical to this Poulan.
Greg Bell - crwdns2934203:0crwdne2934203:0
very clear and well explained, I followed instructions and replaced both fuel lines. The fuel, heat and time just disintegrates these lines. Thanks
Joel Sanchez - crwdns2934203:0crwdne2934203:0
Thank you so much for all the time and effort to make the tough job of replacing fuel lines in these Poulan saws easier. Your thorough step-by-step instruction and photos are really appreciated. Very well done, Sir!
Lynn Wilkens Anderson - crwdns2934203:0crwdne2934203:0
The above article is beneficial for me because here details show how to fix chainsaws. Those people are constructive who have Poulan P3314 chainsaw. Thanks for sharing with us.
Anthony - crwdns2934203:0crwdne2934203:0
Thank you so much for the instructions. It would be helpful to reread the parts talking about where to connect the fuel lines and where the fuel lines are coming from and going to. I understand because I have done this same job on a similar craftsman saw. The carburetor fuel intake is on the right hand side of the carburetor if you are behind the handle as though holding the saw. When the purge bulb is pressed, fuel is purged from the bulb out the long nipple and returns to the fuel tank. When the purge bulb is released, the suction draws fuel from the fuel tank, through the carburetor, and into the short nipple of the bulb. So the path of the fuel is from the tank, through the filter, through the larger fuel line, into the right hand intake pipe of the carburetor, into the carburetor, into the purge bulb, out of the purge bulb, into the smaller fuel line and into the tank. Continually pressing the purge bulb circulates the fuel though the carburetor and back to the tank. Hope this helps someone.
Robert Bradshaw - crwdns2934203:0crwdne2934203:0
I just saw someone addressed the fuel lines in a previous comment.
Thank you thank you! The best instructions I have ever found online. You left nothing to chance. You're the best Chad!!
Terry T - crwdns2934203:0crwdne2934203:0
Thank you. Well written. I think I can do this.
Perisa Lague - crwdns2934203:0crwdne2934203:0
Great pictorial instructions.
Got my old Poulan going again.
Thank you
James DeHaven - crwdns2934203:0crwdne2934203:0
Very well done, really made it easy to do with photos and explanations.
Thank you
Jeff
Jeff - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 26
crwdns2936753:07crwdne2936753:0 225
crwdns2936753:030crwdne2936753:0 964
crwdns2942667:0crwdne2942667:0 84,186
