Porter-Cable PC60TAG Power Switch Replacement
    1. Porter-Cable PC60TAG Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
      • Unplug the grinder before disassembling.
    2. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Holding the front of the device, carefully slide the back cover over the cord.
    3. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
    4. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Careful remove each wire from the power cord from underneath the terminals.
    5. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the spudger, carefully push the red power switch out of the device.
    6. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • From the other side of the device, use the spudger to carefully pry out power switch away from the device.
    7. Porter-Cable PC60TAG Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, carefully remove each of the gold terminals from the power switch. You may need to gently wiggle the terminal back and forth in order to remove it.
Mackenzie Fairbanks
crwdns2935283:003/24/16crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 crwdns2935289:0UMass Dartmouth, Team 2-2, Isaacson Spring 2016crwdne2935289:0
UMASSD-ISAACSON-S16S2G2
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 1,265
