Porter-Cable PC60TAG Motor Brush Replacement
  1. Porter-Cable PC60TAG Motor Brush Replacement, Motor Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the motor brush arm away from the other device.
  5. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  6. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, gently push the motor brush out of the arm.
  7. Porter-Cable PC60TAG Motor Brush Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
Mackenzie Fairbanks
crwdns2935283:003/24/16crwdne2935283:0
564 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 crwdns2935289:0UMass Dartmouth, Team 2-2, Isaacson Spring 2016crwdne2935289:0
UMASSD-ISAACSON-S16S2G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 823
