Porter-Cable 382 Sander Pad Replacement
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Nick O'Sadcia
crwdns2935283:003/11/16crwdne2935283:0
448 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 8-7, Botvin Spring 2016 crwdns2935289:0UMass Dartmouth, Team 8-7, Botvin Spring 2016crwdne2935289:0
UMASSD-BOTVIN-S16S8G7
crwdns2942667:0crwdne2942667:0 1,958
