Porter-Cable 382 Fan Replacement
  1. Porter-Cable 382 Fan Replacement, Sander Pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Fan Replacement, Dust Seal/ Break: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Porter-Cable 382 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
  5. Porter-Cable 382 Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Porter-Cable 382 Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
    • unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
  6. Porter-Cable 382 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
    • Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
  7. Porter-Cable 382 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
    • Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
  8. Porter-Cable 382 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Porter-Cable 382 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now the two guards will come apart as shown, giving you access to the fan.
    • During reassembly, the two guards will line up so that the dust collector opening lines up with the power cord as shown.
  9. Porter-Cable 382 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
Nick O'Sadcia
crwdns2935283:003/11/16crwdne2935283:0
448 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 8-7, Botvin Spring 2016 crwdns2935289:0UMass Dartmouth, Team 8-7, Botvin Spring 2016crwdne2935289:0
UMASSD-BOTVIN-S16S8G7
crwdns2942667:0crwdne2942667:0 422
