Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screws to Base Plate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Screws from the Charger Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 5mm screws from the metal plate.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the metal plate and pull towards you.
    • You may need to wiggle the plate back and forth gently to loosen it from its housing.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screw from Base Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips #00 screwdriver to remove the four 6mm screws from the base cover.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Separating Charge Plate from Base Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the charge plate away from the rest of the base and separate the two pieces of the charge plate.
  8. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    crwdns2942207:0crwdne2942207:0
    • Use the spudger to gently scrape the glue away from the wire connections.
    • If the spudger is not adequate, try using the tweezers to pull the glue away before scraping.
  9. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Desoldering the Wire Connections: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
Jay Gunter
crwdns2935283:010/27/14crwdne2935283:0
378 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Carnegie Fall 2014 crwdns2935289:0Eastern Washington University, Team 1-1, Carnegie Fall 2014crwdne2935289:0
EWU-CARNEGIE-F14S1G1
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 184
