This guide will show you how to swap out the bluetooth sensor in your soundbar. Keep in mind this is a fragile cable that can easily be broken. It must be handled with care.
To reveal the control button, first, carefully remove the front cover of the Sound Bar.
Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
After the cover is fully removed, it will be able to see the interior speaker.
Carefully unscrew all 16 screws to release the panel.
To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
Push the opening tool along the edge of the cover to fully open it.
Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
Can you pair it with Beats headphones.?
wayne rivers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
