Polaroid i533 Zoom Lens Replacement
  1. Polaroid i533 Zoom Lens Replacement, Zoom Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid i533 Zoom Lens Replacement, Zoom Lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid i533 Zoom Lens Replacement, Zoom Lens: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 driver to remove four screws (3mm) on the left side of the camera. Keep all screws for reassembly.
    • Directly on the bottom of the camera there are 3 screws, unscrew all with a Phillips #00 driver.
    • Unscrew two screws on the right side of the camera with a Phillips #00 driver.
  2. Polaroid i533 Zoom Lens Replacement, Opening back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement, Opening back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery door on the bottom of the camera. Then slide the battery door open using the iFixit opening tool.
    • Gently open the back cover of camera.
    • Do not pull the cover off completely, because it is still attached to the logic board.
  3. Polaroid i533 Zoom Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid i533 Zoom Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid i533 Zoom Lens Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the ifixit opening tool, push the black tab connecting the LCD screen ribbon to the logic board away from you.
    • Gently pull the ribbon away from the logic board with thumb and index fingers.
  4. Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver, unscrew and remove the (3mm) screw on the bottom of the logic board above the tripod mount. Keep the screw for reassembly.
    • Gently pull the front of the case off.
  5. Polaroid i533 Zoom Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black patch covering the ribbon that connects the zoom lens to the logic board.
    • Carefully remove the black patch using tweezers.
  6. Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers gently lift the black tab that holds the zoom lens ribbon in place.
    • Gently remove the zoom lens ribbon.
  7. Polaroid i533 Zoom Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver and unscrew then remove the three (3mm) screws shown on the back of the logic board.
    • On the left side of the logic board use the same screwdriver. Unscrew and remove the 3mm screw. Keep all screws for reassembly.
  8. Polaroid i533 Zoom Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid i533 Zoom Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It is now safe for you to remove the zoom lens.
    • To reassemble the device, follow these steps in reverse.
To reassemble your device, follow these steps in reverse order.
Aric Champagne
crwdns2935283:006/24/10crwdne2935283:0
18 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-4, Johann Summer 2010 crwdns2935289:0Cal Poly, Team 3-4, Johann Summer 2010crwdne2935289:0
CPSU-JOHANN-R10S3G4
crwdns2942667:0crwdne2942667:0 2,867
