Polaroid Sun 600 LMS Lens Replacement
  1. Polaroid Sun 600 LMS Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
    On the Polaroid 630 SL Lightmixer you have to hold the flash segment at about 45 degrees to get it out without breaking of small bits of plastic of the holding mechanism.
    Baroon - crwdns2934203:0crwdne2934203:0
  4. Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  5. Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  6. Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Sun 600 LMS Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
    Hello,
    I had the same camera, and because the shutter is stuck, I follow the tutorial to fix it successfully, and I had a question about the left side of the lens it had two adjustment dials here, is that showing in the photo the default value? because I forgot to take a photo before I disassemble it, so I want to set it to the default value. Thanks
    Ivan - crwdns2934203:0crwdne2934203:0
Ian Hosek
crwdns2935283:001/20/10crwdne2935283:0
357 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-18, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-18, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G18
How could I clean the viewfinder? I have a little bit of dust stuck behind the lens
Corinthia - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 11,017
